Qual o mais potente: motor Mercedes em Linha ou "V" ?
Portal Mercedes-Benz Brasil :: MOTORES E TRANSMISSÕES - ÁREA TÉCNICA :: Motores :: Motores - Gasolina
Página 2 de 2 • Compartilhe
Página 2 de 2 • 1, 2
Re: Qual o mais potente: motor Mercedes em Linha ou "V" ?
john, não se irrite com meu anglicismo! é falta de tempo pra traduzir mesmo
Alguns já definiram o conceito de potencia ( que é igual em qualquer configuração, como efeitos fisicos de frequencias harmonicas...que sabedoria
Como explicado abaixo, (e chutado pelo Xenon : pl : ) tem muito a ver com espaço, forma, aerodinamica da carroceria também
Is there a difference between inline and V engine configurations?
There are actually three different engine configurations commonly used in automobiles:
You can find, for example, inline 6 cylinder engines, flat 6 cylinder
engines and V-6 engines. If you built all three of these six cylinder
engines to the exact same specifications -- same displacement, same
valves, same intake and exhaust systems, etc. -- they would likely
perform nearly identically. Displacement is displacement.
However, there would be a number of differences between the engines in use. Here are several of them to give you a taste:
which configuration to use in a car. Variables include cost, space
available under the hood, position requirements, existing manufacturing
facilities, power to weight ratio, etc.
People sometimes get religious about engine configuration.
Check out these links for more information on engines:
- Inline -- the cylinders are arranged in a line in a single bank:
Click on image to see animation - V -- the cylinders are arranged in two banks set at an angle to one another:
Click on image to see animation - Flat (also known as horizontally opposed or a boxer) -- the cylinders are arranged in two banks on opposite sides of the engine:
- An inline engine is long and narrow. In small cars in particular, a
long, narrow engine mounted transversely can allow a very short hood.
In an air-cooled engine, the inline configuration is sometimes harder
to cool. - A flat engine is wide and flat. This gives it a low center of gravity.
- A V engine is a compromise between the two. It tends to be more cubical in shape.
- The inline shape needs only half as many camshafts as a V
configuration (if using overhead cams), which can lighten things
slightly. - There can be differences in the amount of metal required in the block, meaning that one type might be lighter than the other.
- There can also be cost differences during manufacture.
Alan- Usuário Platina
- Número de mensagens : 2336
Em consideração ao Bastião...
Qual a diferença entre um motor em linha e um motor em V?
Na verdade, há três configurações diferentes de motor usadas nos automóveis:
Entretanto, haveria uma série de diferenças entre os motores em uso. Veja algumas delas:
Os projetistas escolhem, entre uma série de variáveis, qual configuração usar em um carro. Estas variáveis incluem custo, espaço disponível sob o capô, exigências de posicionamento, instalações de fabricação existentes, proporção peso-potência, etc.
Existem pessoas que se tornam aficionadas por configuração de motor.
Fonte: HowStuffWorks
- em linha - os cilindros são dispostos em uma linha em um bloco único:
- em V - os cilindros são posicionados em dois blocos dispostos em ângulo:
- motor de cilindros contrapostos (também conhecido como motor oposto horizontal ou boxer) - os cilindros são dispostos em dois blocos nos lados opostos do motor:
- um motor em linha é comprido e estreito. Principalmente em carros pequenos, um motor comprido e estreito montado transversalmente permite um capô bem curto. Às vezes, em motores refrigerados a ar, a configuração em linha é mais difícil de resfriar;
- um motor contraposto é largo e achatado. Isso proporciona um baixo centro de gravidade;
- um motor em V é um meio-termo entre os dois primeiros. Sua forma tende a ser mais c.úbica;
- o formato em linha precisa apenas de metade das árvores de comando em relação à configuração em V (se estiver usando comando no cabeçote), o que pode deixá-lo um pouco mais leve;
- pode haver diferença na quantidade de metal necessária no bloco, ou seja, um tipo pode ser mais leve do que o outro;
- também pode haver diferença de custo durante a fabricação.
beleza Penna,
grato por mencionar a fonte, falha minha.
Para não sobrecarregar à tôa o site ( e tb em consideração ao Bastião ) sugiro que deletes o meu post.
Não carece não, Alan.
O espaço de postagem é ilimitado. Toda contribuição é bem-vinda.
Pelo menos evitamos que o Bastião se irritasse...
Linha ou V, qual é mais potente?
Se você tiver uma carroça e esta for puxada por seis cavalos, importa se os cavalos estão em parelhas ou em linha?
Gortz- Usuário Iniciante
Data de inscrição : 29/09/2008
Interesses : Autos, motos
V ou L
boa noite.. estava lendo o topico e eu tinha essa duvida tambem,, vamos la.
EU acho q o motor em linha gera menos torque do que em V ,( estou aqui pois quero saber, isso é oq eu acho , por isso se eu estiver errado me corrigem ) , mas afinal , qual a vantagem do em L intao?
estava analisando os desenhos dos motores , seus funcionamentos, e tirei uma conclusao
1- motores em linha , me parece q em alta sao melhores.
2- motores boxers (180°) , parece q precisao de pouco esforço comparado aos demais para exercer uma funçao
me corrigem por favor, isso é uma duvida q tenho
e em caso de uma preparaçao ? vcs iriam de motor V ou em L ,
abraço
abraço
- Número de mensagens : 832
Interesses : automoveis
Não sei nada de mecânica, mas o que os "reviewers" dizem é que quando a Mercedes passou a usar motores em V, em 98, mantiveram a potência, diminuiram o consumo e aumentaram a suavidade. Ou seja, não falaram de nenhuma mudança significativa no desempenho.
Krycek- Usuário Platina
- Número de mensagens : 8300
Quantos cilindros? Estamos falando de motores 4 tempos.
4 em linha, 6 em linha ou em V e 8 em V. Essa é a receita básica e a dúvida ocorre nos 6. Como o Krycek falou, houve uma evolução, porém era uma geração nova de motores, logo é natural que fossem mais eficientes.
L ou V , 4 ou 6 ou 8!!!!!!
Não tem por onde, o que importa é deslocamento (cilindrada), taxa de compressão e alimentação ou sobre-alimentação no caso dos Kompressor ou Turbo. O resto é resto. Não tem mágica! Os motores mais potentes da formula 1 até hoje são os quatro cilindros turbo de 1500cm3 e até estimados 1200CV!
Gortz, estamos falando de motores com a mesma cilindrada e deslocamento, ai como fica? He, he, he!
Vejam bem este topico é realmente para criar uma discução saudavel, pois creio que não há diferenças significantes entre os dois, o "V" leva um pouco de vantagem pois é mais compacto, e só.
Motores boxer são motores em linha, tá?
Motores "W" são motores em "V"
Motores estrela, raros em automoveis, são motores estrela, nem em linha nem em V.
- Número de mensagens : 4496
Pergunta que originou o tópico:( Laurival )
"Dois motores idênticos , porém um com os cilindros em linha e outro com disposição em v" .Qual seria o mais potente? "
Tecnicamente, na teoria ou na prática, realmente não sei. Mas ícones em potência e desempenho ,como Dragster , F1 , Veyron etc usão motores em V :arr:
- Número de mensagens : 1402
Acho que só a BMW ainda produz motor 6 cilindros em linha que, aliás, está aprimorando há décadas. O espaço realmente é melhor aproveitado pelo V6, mas em questão de barulho não acho que os V6 da MB sejam mais silenciosos que os 6L da BMW. Os dois ligados, em marcha lenta são quase idênticos. O que os diferencia é o sistema de escapamento, que nas BMs são propositalmente configurados para gerar um barulho mais esportivo e nas MBs o que prevalece é o silêncio.
madvadv- Usuário Iniciante
- Número de mensagens : 32
Data de inscrição : 20/09/2010
» Localização do Número do motor M104
» Localização do Número do motor M110 - 6 cilindros em linha (1972 a 1986)
» Numero do motor c280 em linha.
» Durabilidade de um motor M104 - 6 cilindros em linha
» Peças motor C280 1997 6cc linha M104 W202
Página 2 de 2
