Dados de fábrica das E430 B4
Este site da mercedes possui diversos dados sobre as E430 blindadas de fabrica (B4). Curioso é que as que conheço (a minha inclusive) em vez de vir com rodas aro 17, conforme consta, vieram com as rodas aro 16 da B6 (proteção máxima de acordo com o manual).
Minha intenção é criar aqui um repositorio com informação sobre o modelo para o futuro.
Também pretendo colocar o manual da blindagem com as informações de fábrica.
- Model
W/B 210 E 43 B4 - Description
210.070 - Production
07.1999 - 03.2002 - Combustion principle
four-stroke petrol (with manifold injection and emission control system with closed-loop 3-way catalyst) - Configuration
front, longitudinal; vertical - Frame design
steel unit body - Front-wheel suspension
double wishbone - Rear-wheel suspension
multilink suspension with hydropneumatic level control - Front springs
coil springs, torsion bar stabiliser - Rear springs
coil springs, hydropneumatic spring struts, torsion bar stabiliser - Shock absorber front/rear
gas-pressure shock absorbers - Steering
rack-and-pinion parameter power steering - Brake system (foot brake)
hydraulic dual-circuit brake system with vacuum booster and antilock system, from 03.1997 with Brake Assist; disc brakes front (internally ventilated) and rear - Parking brake (hand brake)
mechanical (foot-operated), acting on rear wheels - Wheels
light-alloy wheels - Wheel rims
7 1/2 J x 17 H 2 - Tires
235/45 R 17 93 W - Driven wheels
rear wheels - Engine type
M 113 E 43 / 113.940 - Number of cylinders / arrangement
8 / 90° V; light-alloy block - Bore x Stroke
89.9 x 84.0 mm - Total displacement
4266 cc - Compression ratio
10.0 - Rated output
205 kW / 279 hp at 5750 rpm - Rated torque
400 Nm at 3000 - 4400 rpm - Number of valves / arrangement
2 intake, 1 exhaust / V-shaped overhead - Valve operation
1 overhead camshaft per cylinder bank - Camshaft drive
double roller chain - Fuel system
microprocessor controlled injection system with hot-film air mass sensor (Bosch ME engine management) - Fuel tank: position / capacity
above the rear axle / 80 l - Drivetrain
divided cardan shaft - Gearing
5-speed automatic transmission - Availibility
as standard - Shifting
central floor gear shift lever - Clutch
dry single-disc clutch - Transmission type
planetary gear system - Gear ratios
I. 3.59; II. 2.19; III. 1.41; IV. 1.0; V. 0.83; R. 3.16 - Final drive ratio
2.82 - Maximum speed
max. permissible speed dependent on tyres: 210 km/h - Acceleration 0-100 km/h
8.2 s - Comments
acceleration by shifting through from 0 - 100 km/h (2 occupants) - Wheelbase
2833 mm - Front / rear track
1534 / 1538 mm - Length
4818 mm - Width
1799 mm - Height
1439 mm - Kerb weight
2060 kg - by Guideline
EC 92/21 (including driver, 68 kg, and baggage, 7 kg; tank 90 % full) - Gross weight
2375 kg - Units produced
not separately documented - Prices
01.2000: DM 218,787.60
01.2001: EUR 112,415.60 (DM 219,865.81)
Marujo_BSB- Moderador
- Número de mensagens : 2916
Re: Dados de fábrica das E430 B4
A E430 blindada de fábrica custava quando nova cerca de 112.000 euros. Hoje (jan 2021) atualizando seriam 154.000 euros ou 187.000 dólares. Algo em torno de 1.100.000 reais. Ou seja um luxo pra poucos....
[ltr][size=13]
Atualmente uma S600 blindada de fábrica da classe w222 custa em torno de 1,6 milhões de ....dólares![/ltr][/size]
[ltr][size=13]
» E430 2000 Blindada de Fabrica R$60.000 VENDIDO
» Toda e430 advantgarde é blindada de fabrica ???
» W210 E430 B4 1999/2000- R$ 25.000,00 - VENDIDO
» Bolsa da suspensão traseira da E430 B4(blindada de fabrica)
» 190E - A história (texto traduzido)
