Reset do ASSYST CLC (C204)
Prezados Confrades.
Estou de volta ao Portal, depois de um bom tempo afastado , pois perdi meu login.
Espero encontrar alguem que nos de a dica de como poder fazer o reset do ASSYST da CLC 200 2010, atraves do painel e volante.
Ja procurei em todos os topicos e nao encontrei este procedimento para a CLC.
Alguem pode me esclarecer?
Obrigado .
Obrigado .
Flyerzenn- Usuário Iniciante
- Número de mensagens : 1
Data de inscrição : 28/01/2014
Re: Reset do ASSYST CLC (C204)
Bom meu caro confrade...
Não sei ao certo se vai funcionar ou não...porque a minha não é tão nova assim...mas achei esses daqui abaixo:
Maintenance Indicator Reset Procedure Mercedes-Benz C-Class 2007-2010 (W204)
Applies to: Mercedes-Benz C-Class 2007-2010
1 | Close trunk lid or liftgate as well as engine hood and doors | Vehicles with code (491) USA version or code (494) USA version |
2 | Turn key in ignition switch to position "1". | |
3 | Press system selection button (S110s3) repeatedly until the basic display "Kilometer reading" is shown in the multifunction display (A1p13) | |
4 | Briefly press variable resistor or dimmer (A1r1) 3 time | An acoustic signal can be heard and the voltage is shown in the multifunction display (A1p13). |
5 | Turn key in ignition switch to position "2". | The "Service indicator" appears in the multifunction display (A1p13). |
6 | Press lower scroll forward/back button (S110s1) | The "Service indicator" appears in the multifunction display (A1p13). |
7 | Briefly press variable resistor or dimmer (A1r1) once | The menu "Oil type" for selecting the specification of the engine oil used appears in the multifunction display (A1p13). |
8 | Select the engine oil grade used by pressing the + and - buttons, setting of specific functions and volume control (S111s1). | The selection option may vary depending on the engine: "Standard", "Qual. 229.3" or "Qual. 229.5". |
9 | Press upper scroll forward/back button (S110s1) to confirm | "Confirm oil reset, press R button for 3 s" appears in the multifunction display (A1p13). |
10 | Press and hold variable resistor or brightness control (A1r1) pressed for 3 s | "Service confirmed" appears in the multifunction display (A1p13). |
11 | Press upper scroll forward/back button (S110s1) | The "Service indicator" appears in the multifunction display (A1p13). |
12 | Press upper system selection button (S110s3) | The multifunction display (A1p13) then shows the basic display "Kilometer reading or temperature display" or the "speed display". |
13 | Turn key in ignition switch to position "0". |
Pedroalexrj- Moderador
- Número de mensagens : 5784
Reset Assyst CLC 200 k 2009
Boa tarde! Sou novo no forúm, comprei uma CLC 2009 recentemente e nessa semana tive que fazer a revisão B, porém devido ao alto custo, fiz fora da mercedes.
O problema é que a pessoa que fez a revisão não sabe realizar o reset do alerta da revisão. Alguém poderia me passar o procedimento para realizar o reset?
Outra questão, gostaria de levar meu carro em uma mecânica de confiança e que tenha experiência com carros da MB. Alguém indica?
Grande abraço a todos.
Hschneider- Usuário Iniciante
Data de inscrição : 11/05/2014
Interesses : Carro
Bem-vindo!
Acredito que o reset seja igual da Classe C e GLK
Em Cotia não sei, mas dê uma olhada nesses tópicos:
W140- Usuário Ouro
- Número de mensagens : 871
Data de inscrição : 23/10/2007
Hschneider,acredito que o diagrama acima,irá resolver!!!
A propósito,receba nossas boas vindas.
Abs ao amigo,
Abs ao amigo,
Raul Dias- Usuário Platina
- Número de mensagens : 4459
- Número de mensagens : 1619
HSchneider,
Apesar de tbm morar fora de SP, faço a manutenção dos carros em SP, no caso, utilizo a Avanti (João Bosco) e WHT (Jair).
Hiro- Administrador
- Número de mensagens : 2642
Interesses : -
Aprendi como dar o reset e é super fácil.
Após ligar a chave, quando aparecer a mensagem de revisão, aperte o botão de reset até aparecer a mensagem dizendo se você confirma o reset, solte o botão do reset e aperte novamente sem soltar que ele irá resetar após alguns segundos.
A minha é 2010 e fiz essa operação semana passada, com sucesso.
Última edição por ivanvilhena em Qui 5 Jun 2014 - 10:17, editado 1 vez(es) (Motivo da edição : Faltou uma informação importante)
ivanvilhena- Usuário Iniciante
- Número de mensagens : 9
Data de inscrição : 05/06/2014
Interesses : Informações CLC 200k
Após ligar a chave, quando aparecer a mensagem de revisão, aperte o botão de reset sem soltar até aparecer a mensagem dizendo se você confirma o reset, solte o botão do reset e aperte novamente sem soltar que ele irá resetar após alguns segundos.
Enquanto eu acho o MB muito pouco amigável com aquele manual do proprietário em português de portugal, encontro aqui pessoas muito interessantes que se ajudam muito.
Assim que eu tiver um tempo (aqui no Rio moro em prédio e o carro está lá em baixo na garagem) vou tentar implementar especialmente o recomendado pelo Ivan.
Contudo agradeço a todos pela atenção.
Vanderlei J. R. Rodrigues- Usuário Iniciante
- Número de mensagens : 12
Data de inscrição : 13/10/2014
Interesses : assuntos técnicos
Consegui Antonio. Não exatamente como o Ivan falou, mas sim com a chave na posição 2.
Na realidade, como me frustrei na primeira tentativa, fiquei dando "tapa em droga" até acertar.
Sendo assim estou inseguro quanto a solução, mas em princípio foi conforme o Ivan ensinou, porèm com a chave na posição 2.
Valeu o apoio, este assunto estava me tirando o sono.
Abs.
Abs.
Faltou acrescentar então na sequência fazer o procedimento com a chave na posição 2.
Vanderlei, a questão é que reset não é algo que se faz com frequência, mesmo fazendo uma vez costuma a gente acaba esquecer mesmo, pelo menos comigo acontece, enfim bom que resolveu! rsrsrsrsrs
» reset do assyst plus
» Revisão Assyst "B" - CLC C204
» Revisão Assyst "A" - Básica - CLC C204
» Problemas ... (W168 não ultrapassava 2000 RPM e apagava - SOLUCIONADO: verificar catalizador
» Assyst B - Peças
» Assyst B - Peças
