SL65 AMG Brabus
Portal Mercedes-Benz Brasil :: Guia de Modelos Mercedes-Benz - Área técnica :: Classe SL ( R/C107 - R129 - R230 - R231 ) :: R230 - 2001 a 2011
Re: SL65 AMG Brabus
:pale: :( :cyclops: :scratch: : pl : : v8 : :d+: :pos: :pos: :pos: :pos: :cor: :juro: :slr: :arr: :mar: :farao:
Traduzindo: que carro MARAVILHOSO!
rom- Usuário Ouro
- Número de mensagens : 632
GR- Usuário Platina
- Número de mensagens : 7430
WC140- Desativado (Recadastramento - registro desatualizado)
- Número de mensagens : 323
2008 Brabus SL 600
Rejuvenated by a substantial model update the fifth generation of the Mercedes SL now starts yet another chapter in the unparalleled success story of the popular Mercedes roadster. The corresponding exclusive sport program comes from BRABUS. Powerful increased-displacement engines with up to 730 hp (720 hp SAE net) / 537 kW of power, a striking designer suit, high-quality light-alloy wheels with diameters of up to 20 inches, professional suspension tuning and custom interior design: The BRABUS program leaves nothing to be desired.
The top-of-the-heap BRABUS power source for the SL 600 is the BRABUS SV12 S Biturbo engine, developed originally for the BRABUS ROCKET, the world’s fastest sedan. 730 hp (720 hp SAE net) / 537 kW of power and a whopping peak torque of 1,320 Nm (973 lb-ft), electronically limited in the car to 1,100 Nm (811 lb-ft), are the result of numerous modifications. During the displacement increase from 5.5 to 6.3 liters the engine’s interior is completely reworked. In addition the engine is fitted with a more efficient turbocharging system and a stainless-steel high-performance exhaust system with metal catalysts. Power is transferred via a reinforced five-speed automatic transmission and a special BRABUS limited-slip differential that is available for all SL models.
A sprint time of 4.0 seconds from rest to 100 km/h (62 mph), 10.5 seconds to 200 km/h (124 mph) and – depending on final drive ratio and tire speed rating – an electronically limited top speed of 350 km/h (219 mph) make the BRABUS SV12 S Biturbo roadster one of the world’s fastest sports cars.
The stainless-steel BRABUS sport exhaust system with four chrome-plated tailpipes is a must for all BRABUS high-performance engines. But it is also the answer for all SL owners wishing for a sportier exhaust note and for a more striking rear appearance of their two-seater.
To add sporty emphasis to the elegant lines of the new Mercedes SL series, the BRABUS designers went into the wind tunnel to develop a strikingly styled aerodynamic-enhancement kit.
The front of the SL receives some added pizzazz with the BRABUS front apron that replaces the production bumper. It features LED daytime running lights as well as auxiliary high beams and fog lamps, and reduces lift on the front axle at high speeds.
The elegantly shaped BRABUS rocker panels each have three entrance lights integrated into their underside. The lights are activated with the keyless fob or by pulling on an inside door handle. The LED lights illuminate the ground on either side of the vehicle and help avoid unfortunate missteps into puddles or holes in the dark.
The BRABUS design package for the latest SL-class is rounded out by a rear component that integrates environmental lighting, a centrally mounted rear reflector and two cutouts for the sport exhaust system.
Just as important for a customized look are one-piece and multi-piece BRABUS Monoblock light-alloy wheels, which can be mounted on the new roadster in four different designs and with diameters of 17, 18, 19 and 20 inches. The largest possible tire/wheel combination on the new SL features BRABUS Monoblock VI, E or S wheels in size 9Jx20 in front with size 255/30 ZR 20 tires. The rear axle rolls on size 10.5Jx20 wheels with size 305/25 ZR 20 tires. BRABUS recommends high-performance tires from Pirelli and YOKOHAMA.
To further improve the already potent handling capabilities of the new Mercedes SL, BRABUS has developed special suspension solutions. For the SL 280 and 350 models with conventional suspension BRABUS offers its sport springs. For all SL models with ABC active suspension BRABUS has developed an electronic module that lowers the ride height by some 25 millimeters. Sport sway bars reduce body roll.
BRABUS high-performance brake systems for the SL-Class are available in four different versions. The largest one features vented and cross-drilled front discs measuring 375 x 36 mm (14.8 x 1.4 inches), and 12-piston fixed calipers. The rear discs measure 355 x 28 mm (14.0 x 1.1 inches) and come with six-piston fixed calipers.
BRABUS also customizes the interior of the two-seater by upping the level of luxury. The list of products includes scuff plates with illuminated BRABUS-logo, an ergonomically shaped sport steering wheel with shift paddles, and an exclusive BRABUS custom interior crafted from an exquisite combination of especially soft yet durable BRABUS Mastik leather and Alcantara.
Link em ingles: [Tens de ter uma conta e sessão iniciada para poderes visualizar este link] com mais fotos
Fonte: Supercars.net
Fabiok- Usuário Platina
- Número de mensagens : 1753
Re: SL65 AMG Brabus
Protetor de tela:
