SL (R230) e SLK (R171) a Diesel?
SL (R230) e SLK (R171) a Diesel? Empty SL (R230) e SLK (R171) a Diesel?
Mensagem por Krycek Seg 10 Ago 2009 - 23:39
Em 2005 a Revista Automobile testou os dois roadsters da marca com motores movidos a diesel desenvolvidos para o Salao de Genebra:
- SL 400 CDI Biturbo 4.0L V8 311cv 539lb-ft 0-60mph em 5.8segs
- SLK 320 CDI Triturbo 3.2L V6 282cv 465lb-ft 0-60mph 5.3segs
Consumo de ambos em ciclo combinado cidade/estrada de 37mpg. (+ou- 12Km/L)
A revista afirma que o ruido em ponto morto e alguns trancos na aceleracao e desaceleracao sao pontos fracos dos motores diesel, mas que nao fazem feio equipando dois esportivos de ponta. Havia previsao de que a SLK fosse produzida em 2006, ja a SL nao passou de um ensaio, uma vez que a marca nao quis macular a linhagem com um motor a diesel.
_________________________________________________________________________
REVIEWS:
2006 Mercedes-Benz SL and SLK diesel
December 01, 2005
By Georg Kacher
Photography by Charlie Magee
MUNICH At this year's Geneva show, Mercedes reaffirmed its commitment to diesel engines by unveiling the two best production-ready, diesel-powered cars ever made, the SL400 CDI Biturbo and the SLK320 CDI Triturbo. Although Mercedes called both roadsters "studies," the SLK version is expected to go on sale in Europe sometime in 2006. The SL400 is unlikely to reach dealers, since Mercedes feels that diesels are not yet appropriate for the SL's brand image, but spending time with the cars proved to us that Mercedes is serious about moving the diesel away from its fuel-miser image and toward the realm of power, torque, and driving pleasure.
We pop the hood of the SLK, take off the plastic cover, and inspect the ultimate in artificial aspiration: a small turbo on the left, a small turbo on the right, and a big turbo right in the middle of the 282-hp, 72-degree V-6. The SL diesel, on the other hand, makes do with only two turbos for its 4.0-liter V-8.
Push the SL400's shift lever into first gear, switch off ESP, hold the brakes with your left foot, and lay on about 1000 revs. When the traffic signal turns green, the 311-hp SL400 peels rubber with an even greater vengeance than the 500-hp, supercharged, 5.5-liter SL55 AMG. With the help of 539 lb-ft of torque, the diesel-engined SL storms from 0 to 60 mph in 5.8 seconds, putting it within about a second of the V-12 SL600 and the SL55 AMG. The SLK Triturbo does even better than that, eclipsing its big brother by an incredible 0.5 second. Both roadsters return sensational combined fuel economy of 37 mpg.
However, on-off idle clatter, rough full-load combustion, and occasionally brutal accelerator tip-in and tip-out prove that diesels still are not perfect. Yet these engines perform remarkably well, even under the hoods of two high-performance sports cars.
There are no plans to bring either diesel roadster here, but we will get Mercedes' new, 3.0-liter, single-turbo V-6 diesel-producing 221 hp and 376 lb-ft-in the ML320 CDI next summer and the E320 CDI next fall, with an R320 CDI possibly to follow.
Engine: (SLK) Tri-turbocharged 3.2L diesel V-6, 282 hp, 465 lb-ft; (SL) Twin-turbocharged 4.0L diesel V-8, 311 hp, 539 lb-ft
Drive: Rear-wheel
Número de mensagens : 8300
SL (R230) e SLK (R171) a Diesel? Empty Re: SL (R230) e SLK (R171) a Diesel?
Mensagem por Marcius Quandt Ter 11 Ago 2009 - 16:28
além de ser um post ecológicamente correto, construir um carro que tem capacidade de 37 milhas por galão (MPG), cada milha equivale a 1,6m aprox. está fazendo 12 km na cidade e mais de 15km na estrada, e ainda produzir mais de 300cv eu acho fantástico,
pq Mclaren e MBs pipocando cavalagem é fácil de falar, mas isso aqui é o futuro, paraBENZ Krycek
you gotta be in America to see that, congrats
Marcius Quandt
Marcius Quandt
Número de mensagens : 170
Data de inscrição : 22/04/2009
Interesses : tecnologia automobilística
Sexo : Masculino País : Coreia
