Classe E Coupe (ex-CLK) - Mais aerodinamica do mundo???
Classe E Coupe (ex-CLK) - Mais aerodinamica do mundo??? Empty Classe E Coupe (ex-CLK) - Mais aerodinamica do mundo???
Mensagem por Krycek Sex 20 Fev 2009 - 0:13
Revista inglesa Top Gear especula que se o coeficiente aerodinâmico da Classe E Coupe se confirmar (0.24), ela será o carro de produção em massa com menor índice feito atualmente. E ainda faz piada com a mudança de nome (ex-CLK): Por que não ELK? Lembrando que foi o elk test que fez a Classe A 98 capotar.
Comparativamente: [Tens de ter uma conta e sessão iniciada para poderes visualizar este link]
0,34 Ferrari F430
0,34 SL 2001 (capota aberta)
0,32 190E 2.3 e 2.5 16v
0,29 SL 2001 (capota fechada)
0,29 W203 Coupe
0,27 W203 Sedan
0,27 W220
0,26 W221
0,26 Opel Calibra 8v 1991
0,212 Tatra T77 1935
0,195 GM EV1
_________________________________________________________________________
17 February 2009 - 11:00
Slippery customer
Have a look at the Mercedes E-Class Coupe
Mercedes has just revealed the new E-Class Coupe, a big swoopy two-door that will replace the CLK when it goes on sale this summer.
The big news – apart from that name change, on which more in a tick – is the slipperiness. With a drag coefficient of just 0.24, The E-Class Coupe is the most aerodynamically efficient series-production car in the world, making it officially more slippery than a heavily buttered eel with a penchant for pickpocketing.
The focus on aero might help to explain the Coupe’s slightly awkward lines: yes, the front end is true to the recently-launched new E-Class, but we can’t help feeling that it just isn’t quite as elegant as the outgoing CLK.
On the subject of which, there’s more than just a name change at play here. While the CLK sat on the C-Class platform, the E-Class Coupe uses (as you’ve probably guessed) modified E-Class underpinnings, so it’s some five centimetres longer and wider than the CLK, though two centimetres lower of roofline. We can only wonder why they didn’t call it the ELK.
The E-Class Coupe will launch in June with the choice of three petrol engines and two diesels. The 250 CDI, with its new 1.8-litre diesel four-pot, sounds an absolute cracker, developing 204bhp while returning 53.3mpg. Across the range, Mercedes says fuel consumption has improved by 17 per cent, but fear not – there’s still a V8-powered E500 to satisfy your penchant for smoky, tyre-mauling fun.
No E63 Coupe yet, sadly, though we’d expect it to arrive later this year alongside, perhaps, a hybrid version.
As you’d expect, there’s buckets of new tech on the E-Class Coupe, including selective damper control, automatic emergency braking and a drowsiness detection system called ATTENTION ASSIST, the capitalisation of which should give you some hint as to how it works. Mercedes’ ‘BlueEfficiency’ green mods – including low rolling resistance tyres and on-demand power steering – are standard across the range.
If you need a bit more ‘grrrr’ from your Coupe, you can spec it with an AMG-developed sport kit too, with bigger alloys, a body kit and sharper steering.
No word on pricing yet, but we’ll see the E-Class Coupe slipping aerodynamically down UK roads this summer. Those poor battered bits of air are breathing a sigh of relief already.
Número de mensagens : 8300
