mercedes_1908-Benz-120-hp
Portal Mercedes-Benz Brasil :: Guia de Modelos Mercedes-Benz Clássicos - Área técnica :: Outros modelos clássicos :: Outros modelos clássicos
- Número de mensagens : 2671
Maurouts- Usuário Platina
- Número de mensagens : 2218
Re: mercedes_1908-Benz-120-hp
(from Daimler Press Release) 120 hp Mercedes of 1906: One of the last original designs by Wilhelm Maybach
Two historical racing cars from the collection of the Mercedes-Benz Museum in Stuttgart will be participating in the 2008 Goodwood Festival of Speed. The 120 hp Mercedes manufactured by Daimler-Motoren-Gesellschaft (DMG) was one of the last original designs by Wilhelm Maybach. And the 120 hp Benz from Benz & Cie. competed in the French Grand Prix in Dieppe exactly 100 years ago.
For the 1906 racing season, DMG for the first time developed a racing car with six-cylinder engine. Wilhelm Maybach had designed this engine – a highly progressive unit at the time – as early as the fall of 1905 with overhead camshaft, overhead valves and double high-voltage spark-plug ignition. The individual steel cylinders are mounted on the light-alloy crankcase. Cooling jackets and cylinder head are made of a single casting and welded to the steel cylinders. This design served as a model for top-performance engines for decades to come. From a total displacement of 11.1 liters, the six-cylinder generates 106 hp (78 kW) at 1400/min and 120 hp (88 kW) at 1500/min – never before had such high engine speeds been achieved in engine manufacture, the result of Maybach’s endeavor to keep the moved masses in the valve timing gear as small as possible.
Ironically, a dispute arose at DMG over the modern design in that several technical details did not meet with the approval of the management, the supervisory board and the company’s most important and highly influential customer, Emil Jellinek. In addition to Maybach being discredited, the internal strife had the consequence that no sufficiently tested six-cylinder car was available for the first French Grand Prix in June 1906. Instead, the company entered three versions of the 120 hp Mercedes of 1905, with four-cylinder engines specially modified for this race.
The 120 hp Mercedes presented by Mercedes-Benz in Goodwood dates back to the year 1906 and forms part of the collection of the company’s museum. It hasn’t been operated in public for a long time – since its entry in the Semmering hillclimb race in 1908, it has above all been used as a static exhibit. Now the car is presented to the public again – and used for its original purpose, namely for racing. This is Goodwood, after all, were the racing atmosphere of bygone times is revived.
Technical data
Technical data
fonte: [Tens de ter uma conta e sessão iniciada para poderes visualizar este link]
- 120 hp Mercedes racing car
- Year of production: 1906
- Cylinders: 6 (in-line)
- Displacement: 11,080 cc
- Output: 120 hp (88 kW) at 1500/min, 106 hp (78 kW) at 1400/min
- Top speed: 150 km/h
» Quem "curte" a marca M.Benz? (brindes que levam o logo Mercedes-Benz)
» SL R107 e R129 Vídeo Bellote
» Mercedes-Benz 280SE 3.5 vs. Mercedes-Benz CL63 AMG
» IMP/M. BENZ 190 E 2.0 13.500,00
» Indiquem oficinas para mercedes da década de 70 e 80.
